MasterDabber
Just want to check that my understanding is correct on these oil changes.... on an 1150.
I should run the bike for a few miles to get the oil at normal operating temperature... say about 5 to 10 miles?
Put the bike on level ground on the centrestand.
Remove oil filler plug, then remove oil drain plug... then refit oil drain plug with a new washer.
Now to the real question....
Should I then refill using a measured amount... 1litre for the gearbox and 0.25 litres for the final drive.
OR
Should I simply fill until the oil comes level with the bottom of the filler holes?
Any other advice???
Thanks Derek
OR
Any other advice???
Thanks Derek
