Hi all,
I have a r1150 gs. I use the bike for long distance travelling to get to predominantly off-road places. So while the bike is fine for open roads, its really not so good for the more knarlly stuff....particularly rocky steep tracks, creek crossings, and soft sandy sections where I'd prefer to keep the revs up a tad without going 100 mph in 1st
Or worse still slipping the clutch!
So, I have been researching a bit and see there are several final drive options and at least a lower 1st gear ratio. The two combined I suspect will be ideal.
The lower 6th gear ration doesnt worry me as I tend to use 4th and 5th when on unsealed road. 6th is reserved for long straight flat sealled sections so having the extra legs is good.
My question therefore are:
-which R models came out with the higher final drive ratios? Are there several options or just the 3:1?
-do the earlier R850 final drives fit?
-with respect the gearbox, does the design allow to change just the 1st gear ratio....or are you committed to also change the 6th gear as well - as I suspect it shares the same lay shaft????
Finally, where should I begin looking for the bits. I notice the US has a good amount for sale but the freight costs are ridiculous. Suggestions would be greatly appreciated.
TIA
TIA
