Charge light staying on
bumpmuncher
wet end of A133
Sorry a little hard of thinking this eve :blagblah
Had a little run today was almost home when I saw that the charge light was staying on untill 3000rpm this gradually increased untill it wasnt going out at all :blast. There is continuity across the slip rings on the rotor the brushes are good. I have tried a known good regulator (It was fine last time i used it :thumb) When i removed the reg and connected D+ and DF together the charge light stayed on.
There is continuity to earth on the 3 phases when the diode board is connected.
Has anyone got any idea what my problem is :thumb2
before whats left of my brain oozes out of my ears :D
replacement didode tried. No change so probably not that :blast brain seems to be working bit better today, so with any luck I will figure it out :thumb
Continuity at sliprings but is there a short rather than a circuit? Mine failed open so it was easy to find the fault. there should be a certain resistance, although low.
still not sussed it :confused: there is continuity on the rotor but no resistance (is this my trouble).
This one is getting to me a bit I can usually figure any problem on the bike out in a few hours, I have had virus/cold thing for the last week and it has made me more stupid than usual :blast
Can I test the rotor by putting 12v across it and seeing if it gos magnetic :D or is that likely to burn it out straight away
Ok shot in the dark.
Had the same problem with the ribena bike, not sure what model /age yours is.
Turned out to be a fried current overload dump relay( think that is what it was called) sat under the tank with the other gubbins cost £7.50.
Think mine is a 92 it only has 3 relays under the tank so will have a further look at them :thumb2 I have now taken the rotor out and had a good look at it, it would appear to have 1ohm of resistance. Is that enough ??
From my notes, a new rotor normally reads about 3 ohms when tested between the slip rings, I haven't got a new one in stock at the moment so can't test one more exactly.
If yours is reading considerably lower, it could be short circuiting.
Oh dear it would appear that 1 ohm isnt enough resistance on the rotor :blast
replacement one has 4 ohms (as far as I can tell) and everything seems to be working as it should :thumb2 lets see how long the bike gos before the gremlins decide to gnaw on something else :D Thanks for the advise and pointers :beerjug:
Edit
Oh well the gremlins have moved into the right carb and decided to soak my foot in petrol :blast :blast
relay
had a similar prob to abrasion's , my relay was coming loose . sorted it by wrapping a cable tie around it .
