Brake light staying on.
daviedevs
North Staffs UK
My brake light occasionally stays on after using the front lever. If I give the lever a quick flick the brake light goes off again.
Is it micro switch controlled as I can’t hear the tell tale ‘click’ when I pull the lever or is a computer controlled thing?
TIA.
It’s a micro switch. You may be able to tweak it’s position or even the switches lever a little
Are they the OE levers or have you replaced them. If they’re a cheap copy they can stick due to incorrect tolerances.
don't think there is a microswitch on the brake lever of the w\c.
