Brake light staying on...
Sunny Jim
Haworth
Just back in from helping a mate collect a 2008 800 - the only problem we found was the brakelight seems to be stuck permanently on. Anyone experienced this before or have a solution pse?
sounds too simple, and may be different on yer new fangled 800 :D , but when I had this problem on my 1100, after buggering about with the front brake micro switchy thing for an age (can't remember why now :blast ), it was the bulb that was faulty :blast :blast :blast. Replaced bulb, problem solved. :thumb2
Recently had this on an 1150 and found it to be the front brake lever micro switch that had worn out. 20p switch from RS components becomes £31 when BMW add there value to it:mad: Doh!
Thanks chaps - came down to a really poor quality micro-switch on the rear brake pedal assembly- £33 new or £17 used @ Motorworks.
BMW you really should be ashamed of yourself!
