Charging a Mac book air on the go
spm0912
Biggin Hill
I have a 2017 13" Mac book air with Retina display with the magnetic connector. I want to be able to charge it from some kind of portable power pack whilst camping. I can charge the power pack whilst riding via the Din plug.
I've completely lost myself searching the net with all sorts of conflicting advice. The only way I can see it done is by buying a powerful power pack with a 12v DC outlet (Ridge monkey, the fishing specialists do one) then get a a car charging lead with transformer but that'll cost over 200 quid for the both of them Is there a cheaper but still reliable way? Doesn't have to be fast, I can leave it charging over night.
Any advice gratefully received
Ta, I don't travel with a top box otherwise that would work. Maybe I should:D
Where were you planning on putting a power pack etc?
You could try a large lithium bike battery, with an optimate-style lead/plug to your bike battery and the charging cable I listed - into a socket connected to the lithium battery too...............
But - you might find your alternator can't cope with the additional load in the morning especially, when the PD/charging is at its max
Get a top box and charge the macbook directly - in there.
Power pack in a tank bag charged from the din socket up front. Mac carried in roll bag on back seat. I do have a top box but generally only fit it when carrying a pillion and it has a din socket in it! A decent power pack with the oomph to charge a Mac is expensive. Think I'll go with your option!
Thanks:thumb
Dont forget to sort out something to ensure that the mag connection doesn't disconnect as you are riding.
A large rubber band around the macbook/plug?
Most portable power banks have a USB outlet. So just get a USB to magnetic thing lead. I got one off eBay.
These are good and have an ac outlet, so you can plug in your MacBook in using your magnetic lead. They come with a cigarette lighter charging lead, so if you can secure the Powerpac, you could charge from the bike while riding...
https://www.powapacs.co.uk/product/atom-2/
Can you post a link to the cable/adaptor? USB outlets from powerbanks are 5v
I've seen these but stories of overheating cables and intermittent working have put me off
Umm, not cheap and quite bulky to carry on a bike but it would definitely provide all my power needs whilst camping. Thanks, I'll look into it a bit more
Newer versions charge through a USB C but I’ve never seen a genuine MagSafe 2 (which is what I think your MacBook will have) lead that goes into anything other than a full sized plug. You could probably get away with buying a very small 12v inverter but as Blackal say, the MagSafe plug will probably drop out unless you put tape over it.
I’m always a bit worried about charging expensive electrical items with Chinese products bought on eBay or Amazon and even though I know the genuine Apple lead comes from China at least I know it’s been tested properly. Do what I did and buy an iPad mini for holiday use. Mine fits into a soft case with my Kindle and goes in the bottom of my tank bag where it’s at hand if I want it on long ferry crossings.
Look in motorcycle sport and leisure mag- august edition. It’s got a kit test on a sealed power bank with a 3 pin plug outlet.
