Will O The Wisp
I have a 1988 R100GS. Well used at 120,000 miles and I have taken it many places. When started with headlight on it charges at 14 volt, after around 10 minutes use the voltage knocks down to around 12 volts for the rest of the ride.
If I turn the ignition switch to side light it is back up to 14 volts.
I have replaced; battery, rotor, stator, diode board, regulator, headlight relay, starter motor relay (I did this as there is a headlight bypass to ground when the starter is used),
all the charging system wiring.
Also I have looked over all the rest of the wiring.
Still the problem persists for about 18 months now, if I keep using it like this slowly the battery discharges.
I am out of ideas apart from a rewire or maybe replace the ignition switch which also does the lights.
Thank you for looking
