Cheap Horn Connector
Speedie
Member
Leyland, England
Hi peeps,
Just a bit of info which you may find useful ! The Canbus horn connector is the same connector as a Land Rover discovery 3/4 or Range Rover sport brake pad level sensor. These sensor wires are about 18" long at least and covered in a nice black insulator. I think the rear is cheaper than the front but at around £8.50 its cheaper than the BM part and you may even get an old one for free from a Land Rover dealer or Specialist. Used one for my Magnum horn today and its perfect - just chop the sensor end off and it leaves you with two wires to bare back and fit spades or whatever.
Just for clarification this is the horn side of the connector which saves you butchering the harness.
Part No.s are SOE000025 or SOE000024 I think but check to be safe.
:) Mick
Even better Fanum - An aftermarket one ! never gave it a thought, although a worn sensor still has good wires and can be had for £00.00
Mick:beerjug:
