Circular autocom speakers
yoxi675
Barnsley, England
I've looked everywhere for circular autocom speakers. I have a set of oval ones which don't fit in my shoei Neotech too well and put pressure on my ears. Are there any alternatives out there ?
There are the 'louder' speakers, they are circular and more compact, albeit a tiny bit thicker. I'll see if I can pop a picture up later if you like.
I find mine is OK with the oval Autocom cases, I mounted them in at a slight angle with the speaker bit in the hole and the other end of the case slightly out of it, pointing towards the top of the helmet.
I then peeled the foam backing off the back of the blanks that cover the speaker holes when no speakers are fitted, cleaned the glue off them with Isoclene (isopropanol), and refitted them over the speakers. Very comfy (well it is with my likkle ears ;) )
Edit, I forgot to say, then wash the covers to get rid of the isopropanol residue
Take the speaker out of the recess, and then a bit of elbow grease with the back of a teaspoon compact the foam down... Simples :cool:
Worked for both of our C3's
Cheers fellas
Popped the speaker out of the oval plastic and they fit a treat. New extension lead arrived today. I now have coms, sat nav and tunes :)
