Emoto
You don't use neutral?
You don't use neutral?![]()
....... also I hope there is going to be no long term damage to the engine due to the engine and gear box using the same oil ,
Because that RT has a proper dry clutch, unlike the WC GS's wet clutch set up
Beta testers - god love them![]()
Stop in first, side stand down, get off bike as the engine stopped automatically and is now the parking brake.
Get on, clutch in, start engine, ride off.
If you stop for any length of time then hit the stop button, release the levers and again the engine acts as a parking brake. The starting load on the starter is much reduced with the centrifugal decompressor on the LC.
Off roads skills taught me the no neutral method and it had probably saved me a week of my life so far.
JS, It's like Muppet Central! The new breed of GS owners, God help us!
Got mine back from Bahnstormer yesterday.
Before stripping down the clutch they checked the fluid levels and found the clutch fluids to be overfull.
They pulled some out and hey presto - everything is much better.
JT
Sorry Engineer you sound like a Bl**dy BM Dealer
Can we all please just stick to the facts.
THE GEAR CHANGE IS SHITE AND NEEDS FIXING
that way we can get away from all the misleading speculation
Not true! - the vast majority of complaints have come from the newbies who have limited experience of bikes in general.
Much much much better and all I did was start to undo the cover screws and the fluid forced its way out as shown in the picture. That suggests to me it was too full and BTW the engine was cold. I did draw out a small amount of fluid once the cover was off then refitted and took it for a ride. It's so much better and there is no need to have the clutch lever travel set to max.
And we have a breed of no it all fooking igiots that don't even own a wc they should do one back to the pensioners section.
Wow! This is amazing. Just to be clear, you are saying that now you've adjusted the clutch fluid level down, your shifting is improved? If so, would you say it has improved to the point of being in the range of what we might call normal?
Edited to add:
So, of course, I had to go out to the garage and check mine, especially since I have a bit of intermittent rough shifting. And...
MINE TOO!!!
It is raining fairly hard here (just washed the bike of course) so I have not taken it out to test shifting action yet. I hope this improves things.![]()
That is arrogant beyond belief.I don't hold with angry responses and personal slights, but you have just proved how narrow minded you are.
