Cleaning between the fins.
Noddy
Some sort of clique thing
Thetford, Norfolk, England
Wire and rotary brushes aren't deep enough or too wide. Don't have time for an engine out job but the barrels and heads look a dull grey mess and need a tidy. Takes a bit of time.
Paint supply shops in Oz usually have various types of Scotchbrite , and a sheet of the brown one, which has aluminium oxide grit, works OK.
If you cut a couple of 100 mm dia pieces and mount them on a spindle between a couple of bits of 80 mm dia ply it make a good mop for cleaning up nicasil or galnickel bores too, and a is a bit ckeaper and easier to find than the stuff with diamond grit used by the OEM manufacturers.
