fayeslane
Always lots of questions re how to clean engines etc so had time to do a bit of an experiment today and here are the results -
Wheel cleaner used as directed. Treated side on left.
Oven cleaner (non caustic)
Wheel cleaner scrubbed in with brass wire brush
Bead blast (glass bead)
Bead blasting is definitely the best option of these. The wheel cleaner applied with brass wire brush has potential for relatively clean surfaces ( not obviously different in the pics but came up a bit cleaner) . The oven cleaner is best used in your oven.
I have seen some excellent results from vapour blasting and would be my preferred option if I was outsourcing the work.
Hope this is of some use.
