clutch biting point
steadysteve
Lincolnshire
R1150GS-- Does it mean the clutch is fubar if the biting point is reached very quickly, ie as soon as the clutch lever is released? Can`t see any means of adjusting it. Fluid level is just above halfway up the sight glass.
Hydraulic clutches are self adjusting and don't have free play like a cable operated clutch so the bite point will happen pretty soon.
Sounds par for the course. However, since your asking the question I assume you've either: 1) Just got the GS and are unfamiliar with it or 2) You've had the bike a while and the biting point has changed. For what it's worth a biting point close to the bar means the clutch is in good order. A biting point near the end of the travel will mean the clutch is worn out.
Regards
Rob C
Yeah just got it as a project. Its my 4th GS and the only one to be so quick on the clutch. Its almost impossible to slip the clutch for manoeuvering around for example.
Have you tried bleeding the clutch hydraulics? Could be air in the system leading to minimal lift/clearance when lever fully back to grip?
Probably be as well changing fluid at the same time if it looks old/dirty:thumb
Cheers...................Grizzly:beerjug:
Will try bleeding it. Dont know when it was last changed but it looks a bit too dark to be healthy. Ta
Bled it through until all the old stuff had flusned through. There was a bubble or three- biting point more controllable now:thumb2
Regards
Rob C
Which part of self-adjusting don't you understand?
