It all depends how long the clutch was used while contaminated with Dot4 . If the clutch was slipping the friction plate would absorb the dot 4. So you can clean the surface and it appears all good, refit it but once it gets hot again the absorbed fluid can creep back out. So as I said, depends how long it was exposed to dot 4 and much has been absorbed.
