my bike is back together now and working thus far... time will tell if something rattles loose (cue months of riding paying too much attention to any weird and wonderful noise, assuming its some catastrophic failure...)
the pressure plate and cover plate kit id bought from motorworks wasnt happy in the bike at all. when installed the pressure plate springs were compressed too far, meaning that when i got the gearbox back on, the push rod was so far in that the slave cylinder was maxed out onto its retention clip and there was no more room for it to actuate the clutch. i thought this was user error to begin with, so stripped and reattempted 2 or 3 times, re-evalutating my approach each time to try and spot an issue but i couldnt. decided in the end to trial fitting the old plates with the new friction disc and hey presto, the push rod sits in there perfectly. so i removed the gearbox, torqued everything to spec and continued to reassemble.
one epiphany id had during the week was potentially using some ratchet straps to pull the front and rear of the bike back together (looped through the tank crash bars and the rear pillion peg hangers), and with a bit of wiggling this approach worked perfectly, meaning i didnt have to call in any family assistance, and had ample time to move around the bike bit by bit to assess the situation and route cables etc. i also decided to leave the driveshaft out for the remating, and then re install by dropping the final drive which removed the need to wiggle and rotate that to fit half way through the process. obviously a bit of faff as i had to mess with the final drive but removing snag points at that stage was more important for me at least.
i decided against reusing the oem throttle body clamps in favour of some blackened stainless steel worm drive clamps for ease of use (and some tarty aesthetics!). a few thousand cable ties and the bike was back together.
a quick re check of the clutch symptoms and... Sierra Hotel Indigo Tango... still misbehaving... some choice words later and half a bottle of the v10 bmw fluid, bled in every single different way and angle imaginable and the bike now seems to be behaving...
so now i have stressed myself over the issue, spent two weekends fettling and will now have a season of riding worrying about and constantly rechecking the bolts... for what might just have been some persistently trapped air
i normally enjoy fettling with the bike but i've also had to repair a few things on the car to get it through an MOT, and now it needs a steering rack... so needless to say i'm a bit sick of wrenching at the moment!
fingers crossed motorworks will take a return of the plates i found issue with, and i will try to build enough trust in the mechanicals of the bike to take it somewhere scenic over the summer
bloody bikes... who'd have them!
