Clutch lever rotation
mpgscott
Isle of Scalpay, Western Isles
On a 2009 RT how do you rotate the clutch or lever assembly? Looking to move the assembly round slightly for a comfier control. I tried slackening the Torx on the end (not bar end) and its not shifting so started looking around.
Fixed position, :(
if you remove swithgear covers, you will see a small screw in the lower unit which screw into the bar to prevent rotation
if you remove and redrill & retap you can in theory can rotate the bar
(thats when you find out they been mooved 12 times allready, and the bar looks like a swiss cheese :)
