emasen
Hi All,
Beginning to get desperate. Recently at dealer for 38000 service, mentioned clutch bite point issues from hot to cold as now getting dangerous also mentioned difficulty in selecting neutral and clonky gearchange at times.
Came back to collect, service done but no result on the clutch issues, he commented that if it persists I would be looking at a full clutch replacement...
200km ride home and no real difference to the clutch issues, bite point still wildly variable, especially when hot.
Decided to replace the clutch to see if it would solve any of the problems. U tubed it to see was I up to it ,got the parts and away we go last night.
Followed the directions removed all parts, no visible damage to clutch basket... perfect. Pressure plate a little scored on the friction surface so replaced that. Removed all the spacers and discs in order and replaced them in the same order, refitted new pressure plate,springs and bolts no problems.
Went to test the clutch operation was OK...... PROBLEM..... clutch lever now wont pull.
Back again, removed everything back to empty basket thinking something had been caught preventing it working. Tried again, Clutch Lever still wont pull. Clutch lever operation was perfect before I started....
Where do I go next, what am I looking for, did I miss out on some stage of this job...... help appreciated.
