Clutch lever
gspod
Back home
The clutch lever span is too great for my wife and it's adjusted to the nearest setting. Is there a mod or a further adjustability option to make it more comfortable for her - she gets bicep ache riding through cities.
Many thanks
Aftermarket leavers, have you checked what's available.
The LC clutch lever operates 2 microswitches essential to rider modes, cruise etc. If you go the aftermarket route, do your homework to ensure you maintain functionality.
Thanks for the replies and info.
Wunderlick looks good - has anyone had any experience with any of the aftermarket ones?
Thanks again
I have these fitted, and they are ace. BMW HP adjustables.
I put some pazzo ones on my gsa just make sure you set them properly as you could end up with the clutch slipping
I have the wunderlich length adjustable ones and they work well BUT I have to ask you if you have tried adjusting the span using the hex headed plunger which actuates the master cylinder?
It's an adjustment that often gets overlooked. It is locked in place by a small, threadlocked grub screw.
By the time you've forked out for some of f these levers, it'd probably have saved you money if you'd got your wife's fingers extended! :D
A great spot .... Good info.
Thanks for all the replies - I shall look into that adjustment.
We were touring the lakes this weekend and it may be more of a handlebar position issue so I'm on the lookout for some Rox Risers.
Her hands are big enough thanks :eek: :D
