Clutch lubricant
  • Thread starter Thread starter aussben
aussben
Hi All,
I am currently replacing the clutch on my 1100gs I got 57k out of it pretty good from what I here just on the rivets.
I wanted to know if anyone new what type of grease you use to lubricate the diaghragm to the inner plate and pressure plate? There is this really sticky white grease used from factory. Also in my hast I removed the clutch without marking it, but the original factory marks are still there. I know that the alignment is 120 degree's apart does it matter which part you start with first when aligning? i.e flywheel, inner plate, outer pressure plate.
