DavyMac
I've been losing pressure occassionly whilst de clutching indicating a hydraulic leak. I suspect the banjo bolt connection between the slave cylinder and bleed line (corroded) but haven;t peeled back the sheath yet. However, I removed the slave cylinder and it was quite 'oily' inside. Is this normal lube or would it indicate hydraulic leak? Should it be dry in there?
