GBgolfman
Its on an Rt 2002. Does any of you guys know about the code plug which is pink that you can change for the olive green one from a GS that will solve the surging issue?
Also when you rmove the code plug and run with not one in it runs fine almost no surging but it seems to affect the top end grunt a bit. Can it do ant damage running without a code plug?
Any other help would be appreciated. The bike is in tip top tunning form so its not a service issue.
