Coil stick melted!
Slime Bomb
Stoke on Trent
A while ago my 1150gs adv was not quite right. Running a bit lumpy on start up and a little hesitant on acceleration. So, having had this about 40,000mls ago I whipped out the coil sticks. All looked fine so changed the spark plugs and everything was good..well, so I thought. It came back again so, coils out again and I noticed this on one of them :eek:.
Anyone had them go like this before?
That's what happens if the coil stick has failed and been left in place for a long period.
They can catch fire or expand and look like someones sprayed a can of insulating foam over the rocker cover.
The wiring and connector plug can also burn and why BMW offers a repair section of wiring for just such a scenario. .
Would anyone recommend putting a thin smear of silicone grease or copper slip on the outside of the stick before fitting or just dry and clean?
I put silicone grease on mine. Although the ones I have currently installed, seem better made. think someone said they are the same as the 1200's?
Last year, while being MOT'D one went up in smoke
