Coloured tyre spot
I always thought next to the valve.
However,someone posted a lot of interesting info regarding the different coloured dots on tyre sidewalls in a thread called,I think,TYRE CHANGING.
Have a look for that one,to avoid four pages of repetition.
Hi Noddy
After last nights differing opinions, I contacted Continental Tyres (TKC80's) and asked them!
Their reply is quite clear :-
"Hi Ray,
So called "balance dots" should be fitted by the valve because it represents
the lightest point of the tyre and should always be placed by the heaviest
point of the wheel, which is the valve.
If you think about it, why would tyre manufacturers mark the dot so that you
would have to place it opposite the valve? After all, wouldn't it be a
difficult task to align the dot exactly opposite the valve? Better and
simpler to mark the dot on the sidewall so that you fit it by the valve.
When a tyre is manufactured there is always a small amount of overlap of the
carcass plies and belts, and the point of this overlap will become the
heaviest point of the tyre, so the tyre manufacturers place the dot opposite
this heavy point, which means you then align the tyre's light point with the
wheel's heaviest point.
While this reduces the amount of balance weights required it does not
eliminate the need to have your wheel assembly professionally balanced.
Regards
Bryn Phillips
Technical & Sales
Cambrian Tyres Ltd
Continental Motorcycle Tyres UK Importer"
So................ both you and I were wrong and Polar Bear was correct, sickening isn't it!
Ray
Nope not really :D :D
I'd just like to say a couple of things:
Nah nah nee nah nah :dabone :D
RayS said:
Hi Noddy
"Hi Ray,
Regards
Bryn Phillips
Technical & Sales
Cambrian Tyres Ltd
Ray
I've just rubbed all the spots off yours :D
Oh yeah, so I have one little mishap that was obviously caused by incorrectly fitted tyres,
So whats your excuse then seein as yours was fitted properly :P :D :P :D :P :D
RayS said:
Hi Noddy
"Hi Ray,
Regards
Bryn Phillips
Technical & Sales
Cambrian Tyres Ltd
Ray
No excuses , I just can't ride very well............
When I have your years and years and years and years and years and years and years and years and years and years and years and years and years and years and years of experience I hope to do better :dabone :D
