Compatability ?
Onahi
I have the Motorrad concepts/Migsel dash mount for the 1150. I’ve taken the street pilot mount off, the four screws to reveal six screw holes on the mount. Does the Zumo 660 Mount screw straight onto this?
Im probably going to purchase the 660 soon.
Regards
Nigel
Here is my mount with the 2720 mount removed. It has nine screw fixings.
Regards
Nigel
I have just done the same, only on an R1200RT, the Garmin bracket holes for the 2610 line up perfectly with the new mont for the Zumo 660 (xmas pressie, cheers the wife)
So you will be fine:rob
Hi Cap'n
That was just the reply I was hoping for, seams someone down the line in the past had the sense to keep everything universal. :thumb
Is your mount exactly the same as mine then, as some later versions just had the ball?
I have the Migsel mount with the flat plate & tapped holes,and the Zumo 660 bracket fitted fine, although I have now updated to the Touratech holder fitted to the Migsel mount with the Zumo 660 in that.
Ken :thumb2
Ken :thumb2
What are the benifits of that? Can you post a picture?
Nige
New Zumo 660 fitted on existing mount. Very pleased with it.:)
If faced with this again, look at the holes, take a measuring stick and check, they should be approx 38mm x 30mm pitch (in other words match AMPS fix pattern) which garmin use in their cradles.
HTH ;)
HTH ;)
:blastWhy wasnt this posted when i first asked (A few weeks ago)
Oh well, someone will benefit from it in the future no doubt:thumb2
