Brendan
BMW R50US 1969.
I'm having a problem with the above bike and would appreciate if you could read my report and if you have the time possibly reply with some suggestions. At this stage I've gone grey and nearly bald as a result of this bike.
So here goes;
When cold the bike will start first or second kick, never needs more teasing when COLD.
When run for 3-4 miles power reduces. Bike will splutter and hesitate when revs are let go low. If you then stop the engine it will not restart until cooled.
What we've tried today;
Compression when cold 130psi on left and 120psi on right, both after 5 kicks.
Compression when hot 60psi on left and 70psi on right, both after 5 kicks.
No noticeable smoke from either exhaust pipe.
No noticeable smoke from crank breather pipe.
Heads removed again today to check for sticking valve stem, all seems fine.
Checked the valve clearances when hot as well and they are + 0.05mm above cold set.
No signs of blow back into inlet port from exhaust.
No oil leaks around head gasket.
Work carried out on the bike;
Barrels honed.
New piston rings fitted.
New valve guides and valves fitted. (proper job by machine shop, old timer)
New head gaskets.
Heads bolts torqued down as per spec.
Valve clearances set and checked several times.
Rocker end float below 0.05mm.
New mag coil and condenser.
New points, plugs and HT Leads.
Please help.
Any help would be greatly appreciated.
So here goes;
Barrels honed.
New head gaskets.
Please help.
if the heads are still off, try inverting them and filling with petrol to see if valves are seated well ?
