connecting an optimate
twizzle
Devil may care...
Clarity
Is it ok to plug an optimate into the aux power socket on the engine ? Subject to getting the correct plug?? i understand you can get them at Maplins... anybody know what they are called?
another option is to get an optimate battery adapter and leave under the seat... but if i can just plug in that would be great!
apoligies if there are lots of threads on this allready..........:hide
It depends which GS you have. If you have a Can bus one (eg, 1200GS, 1200TR, HP2 etc...) then you can't just use the accessory socket and you will have to wire in a Optimate connector straight to your battery. If you have an 850/1100/1150 then you can just connect it to the auxillary socket:rob
AndyT:cool:
No problem if you have an 1100 or 1150 but I believe that there where some issues with the 1200's due to the Canbus system? There are threads on the forum about this if you have a search.
I use the aux socket to 'float' my 1150 with an optimate charger whenever it's sat in the garage.
eBay item number 200267053200 will also do the job.
Job done... item bought from Elite Motorcycle services......in post tonight.
Thanks for all your help!:beerjug:
