Just like mine looked a week ago which are now currently being replaced. Mines a twin spark too.
Hopefully not too dear![]()
£80 per coil (daylight robbery)
Leaving a bike parked for 12 months can cause all sorts of condensation related issues. This is probably just surface rust. Its also not been used wet so quite likely the coil internals are ok.
They sit in a place which gets very hot and when it rains, any water that gets to them will quickly turn to steam.
Check the resistances. You will need some longer than average prongs on your multimeter or very small insulated croc clips. If the readings are fine clean the coil(s) and use it.
Question to the real experts (Im just a home mechanic). Are there any other stick coils that will fit the R1200? Maybe a vehicle parts factors would be less costly source of replacements.
Mike i i feel you may be over thinking this , get the throttle bodies balanced first then give her a damn good run with fresh fuel etc .
then if it still don't feel right then investigate further , you had your last bike so long and did so much with it that this one will never feel the same.
it may take you a wee while to get used to it.
a problem i will face when i return to another 1150 in a few weeks.
motorworks do them for 36 quid inc vat
if they rust they can expand and split (theyre a pain to remove if this happens)
i have them on my kawasaki and theyre 110 quid from kwak
a little number hunting and denso ones were 32 quid each
Couldn't agree more!
The worste that could happen if you have a failed stick coil is it catches fire. No problem![]()
i think Mike has seen enough fire one GSA in flames is enough for one lifetime![]()
For piece of mind, take the lower plastic cylinder guards off (if you have them fitted or any other guards) so you can gain easy access to the lower secondary plugs.
Take the bike for a nice run to get it nice and warm. When you get back with the engine still running pull each of the lower secondary plug leads off one at a time. If the bike stops, then the stick coil on that side is duff. If the bike keeps running then your coils are OK. You've got them nice and hot on the run so any problems should be highlighted.
How they look is no judge of how they perform.
I've had perfect looking coils fail, and ratty, corroded coils that continue to perform perfectly.
Glad you got it sorted Mike. It's made interesting reading since I'm also new to twin sparks.
Is there's any technique in removing the coils from the head? I've read you need to be careful but having never done it i can't see what would be difficult or what to be careful of? Is it just a case of pulling out in line with the tunnel it's in?
Sent from my GT-N7105 using Tapatalk
