Cruch washers
Colm Cummins
Drogheda, Ireland
Hi all ,
Any one able to tell me the sizes of the crush washers needed for service on R1150gs?
Engine oil
Gearbox
Shaft
Thanks in advance
Colm
Hi Colm,
I don't know how much use it is, but two of them are 14.5mm internal diameter and 1.5mm thick. I think these are the ones off the final drive. I don't have any loose ones for the other plugs. I think the sump nut is larger.
If you haven't already bought an oil filter, I bought a genuine BMW filter in Duffy's and it came with a little bag with all the crush washers.
Cheers, I have the filter, I will look up the microfiche
How about I do you in better and give you the part numbers, I know them off by heart
Engine - 07119963252 x 1
Rear axle - 07119963200 x 2
Gearbox - 07119963300 x 2
