Crush washers - choice of two
Santa-2512
Omnipotent one
North Pole
Looking at doing the gearbox oil ...
Recommendation is to change the crush washers on the filler & drain plug
Looking at the oem sheets they show 2x part 13's
each has a different part number ??
13 Gasket ring A14X18-AL 1 07119963200 $0.38
13 Gasket ring A18X22 1 07119963300 $0.57
Doesn't say which one is which...
Which ones do i need ?
Mart
Mart
just done mine, I'm sure they are both the same
I have reused them in every bike I have owned . Thats about 20 years worth of self servicing. Never a leak.. But I guess , if you are in the shop to buy oil and they are cheap. Why not.
You can heat them but don't go mad. TBH I never have and they were ok.
If you want a certain seal use a Dowty washer.
Ive also re-used the alloy gearbox washers without any leaks.
