fred_jb
I weigh 11 and a half stone so with riding gear, helmet, boots etc I would have thought I was pretty average weight. I'm surprised that Auto seems to think that it should be on minimum preload for my weight.
Sent from my VOG-L29 using Tapatalk
Because these bikes can be set to a very low MIN ride height position and a very high MAX ride height, then I think they must have a normal preload position somewhere between these extremes, designed for what BMW regard as an average rider weight and I assume that is what they are calibrated for. If the bike were loaded with that exact average weight then once it adjusts the preload would be at this theoretical default mid-position.
A lower weight rider will not compress the suspension enough to get down to this normal ride height, and the bike would ride high, but in this case the system then can back off the preload from the normal position once moving and should do so just enough to lower the bike to the standard ride height. There is no reason for it to carry on removing all preload and dropping the bike to the minimum possible ride height, and it should not do this. IMO anyone who tells you it should do this does not know what they are talking about.
Similarly if a heavier than average rider is on the bike then the bike rides lower than the standard height initially, but once moving just enough preload is added to get the bike up to the standard ride height. I know from experience with my 1200 and now my 1250 that this is exactly what happens. I am about 13 st 7 and when I ride the bike solo in AUTO mode I can comfortably get my feet flat (low chassis version bike). If I select MIN the bike drops lower to the ground, and if I select MAX I am on tippy toes.
If after riding it solo my wife gets on the bike, it drops to somewhere near the MIN position, so much so that if I don't retract the sidestand before she gets on there is not enough ground clearance to swing it back. However after we have been riding a short distance the bike adjusts and next time we stop I have the same comfortable flat footing I get riding solo. It will do the same with luggage as well as a pillion, and without disclosing my wife's exact weight (she is about average weight), obviously the bike has plenty of adjustment available.
Conversely, if I last rode the bike two-up, next time I get on it solo the preload is still set for the extra weight but because the weight is now less there is too much preload and the ride height is too high, leaving me on tippy toes again. But as in the previous example, once I have been riding a short distance the preload adjusts and next time I stop I can flat foot again.
This is obviously only my take on how this system is supposed to work, but if I am correct, then yours is quite evidently not working in the way it should.
