oddone said:
r1150gs production started ca. August '99, with BMW / FAG ABS II as an optional extra.
I'm quite capable of "interpreting" what my brakes are doing when I apply the handbrake. You don't have to be Rossi to detect that the rear wheel is locked...
Yes, but the LINKED brakes weren't introduced until ABS III / EVO, which was (IIRC) 2003, which is why we're all confused. It's not that we don't believe you when you say that the rear is locking up (we're not there to see), it's just that something else must be going on instead. Some options:
- Someone retrofitted the linked brakes, or fitted the linked brakes off another bike. Quite why anyone would do this is a mystery to me (I hate linked brakes), but there's no technical reason it's impossible.
- You are braking with both front and rear brake, in which case it is very likely that the rear will lock up, as you have less feel with the rear than with the front (you are using a foot in a boot, less sensitive than fingers in gloves), and the weight transfer means there is very little pressure on the rear tyre, so they tend to lock up very easily, especially if you're used to braking with ABS. I am, and I find myself always just grabbing a handful of brake, and letting the ABS sort out the mess.
- Your engine idle is set very low, and when you bang on the front brake, you are not pulling in the clutch, and the engine is causing your back wheel to lock.
oddone said:
The instruction manual (in Swedish, no misinterpretation there either) states that when the ABS malfunction, the brake system will function a a normal brake system without ABS. What worries me is that it doesn't, as hyraulic pressuse is delivered to the rear brake.
I think I will have to discuss this with the local dealer and get their take. But thanks for the help anyway.
You'll definitely have to discuss this with your dealer, it's the best course of action. As the manual says, when ABS malfunctions, the only difference in braking should be that the anti-lock stops working.
An idea for how to test whether the front brake is also operating the rear:
- Put the bike on the centre stand, and start the engine
- Put the bike in gear, and let the rear wheel spin (you might want to weigh or tie the front wheel down, so the rear can't touch down and launch your bike off the centre stand)
- Pull in the clutch, and then brake using the front brake ONLY. Best done if you're standing next to the bike, that way you can be sure you are not touching the rear.
- If the rear wheel locks, then your front brake lever is operating the rear. If it doesn't, then it isn't and something else is causing the rear to lock.
Let me repeat, it's not that we don't believe that your rear wheel is locking up, it's just that I (and probably the other posters here) have never heard of a '99 1150 having linked brakes. That's not to say they don't exist, just that they were not standard.
