I have checked out to GS-911 and unless you purchase a professional you only get limited vins, also if you don't purchase the Bluetooth version you need a laptop. Professional GS 911 runs out around £500 and if I'm correct it is web-based. Were the duonix-bikescan-100 has unlimited vins and is diagnosed through the actual hand held set. Coming in at a cost of around £350, not really sure which one to go for. Was just wondering if anyone had any experience with duonix-bikescan-100.
Thanks for that DrFarkoff, I will probably opt for the GS 911 professional as the vins are important as I intend to do my own service in probably at shorter intervals than BMW. If that is the one you would recommend may ask if you have used one and they are relatively easy to use? Probably go for the Bluetooth version so I can take it with me on longer journeys.
looks good Ian, wounder if it gives you the option to download in English? Also cannot find a ELM 327 for the BMW motorcycle everyone just states cars!
