DialDim™ Lighting Controller – Universal Fit
MartinK
Clackmannanshire
I have a pair of Denali S4 on my Guzzi V85TT
They're far too bright to use (unless on full beam) for normal riding without a dimmer. For the last couple of years I have been using a Skene IQ-275 dimmer which has been great. I have the S4's on at 20% brightness all the time as DRL. This is bright enough for extra visibility (for drivers to see you, when riding with the bike's DRL on only). I live down country lanes, so when using full beam I get the full brightness. It's been a very good setup.
Last time I was out on the Guzzi, the S4's were not working. The Skene had failed. I tried a few things but it was dead.
So I splashed the cash and bought a "Dial Dim" from ABIKETHING - https://abikething.com/product/dialdim-lighting-controller-universal-fit/
It was simplicity itself to fit. It took a couple of hours but most of that time was taking the tank and panels off the Guzzi. The kit was plug-and-play. I am very pleased with the result. I now have a dial on the handlebars and I can vary the light output of the S4's on the go.
It also has CANSMART/EZCAN functions, so I can wire it to the indicators and have different functions. It also has the ability to daisy-chain a Denali horn to complement the original (crap) Guzzi horn (a later upgrade I think).
Anyway, just a quick product check-in. Very impressive piece of kit. Does almost everything a CANSMART/EZCAN does, but you can fit it to any bike (or any vehicle) quickly and easily, and you can move it bike-to-bike if you swap bikes... An investment protection if you like...
Maybe this is the route Denali are going because I see you can get vehicle specific kits for the Dial-Dim for Africa Twins and the new Triumph Tigers...
Video here​
<iframe width="560" height="315" src="
" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Hi Martin, thanks for this post.
I'm about to fit a dialdim to my V85TT, maybe you can help me.
Do you remember where did you connect the cables to the high beam, the turn signals and the switched power?
Thank you very much
Thank you very much
Hmmm, on my V85TT the previous owner had wired spots to come on with full beam only, so I just used the trigger wire he left.
On my Stelvio V100 it was a pain in the butt. The main beam is triggered by a 0v line from the LH switchgear. I tried the Denali Trigger (see https://www.ukgser.com/community/threads/v100-stelvio-hi-beam-trigger.445293/ ) but that didn't work! I had a few email conversations with the Denali Help Desk and then gave up. I have a seperate switch to use full beam on the Denali's. The Dial-Dim is left at 15% or 20% intensity (more than bright enough for DRL duties!), and I have to press a seperate switch to igniter 100% intensity
Little update: problems here as well. It's a my24 so I think the guys are having the same issue you have with your Stelvio.
No 12v signal for high beam lights, so the DialDim controller do not knows when to go 100% as it needs a 12v signal.
