Digital Set Top Box
  • Thread starter Thread starter Paul Narramore
Just for Cookie...better get your wallet out then :D
Pace
Twin DigiFusion FVRT100
DigiFusion FVRT150
DigiFusion FVRT200
Thomson DHD4000
Panasonic TUCTH100
Inverto IDL 7000
Topfield TF5800T
Humax PVR9200T** Sagem
PVR6240T
PVR6280T Sagem
PVR7280T
Bush IDPVRO2
Bush IDPVR802B
Twin tuner freeview with HD's
Hi Guys,
For once, I am asking ...
I want to add a Freeview box, so I know 2 scarts instead of one. The signal in my area is good and those I have spoken to say the digital signal is better than the analogue. I do not intend to record - so have disconnected the video from the TV (just have a scart link for playback), so its off-air directly in the TV ( not via the video and noticed Five signal improved from the UHF channel 37 band).
So with a £50 to shell in the high Street what do I go for as brand (prefer some thing I have heard of) /make/model, etc ?.
Is there a Which guide on choosing the right box ?.
RAM-man
i bought one of these recently to replace a rather crap nokia box. very pleased with it.
i do have to say, that digital picture is not up to analogue on any tv i've ever seen. it's OK though.
Cookies seems like a good box... to be honest i don't really know much about the boxes themselves... most are much of a muchness the ones that have a 7 day epg are good.
Big names do not necessarily mean good boxes
the Nokia boxes can freeze.. and i've seen bad picture from Pace boxes.
some come with scart leads others don't so take this into account when looking at prices
Cookie & Tuned-in
Thanks for dragging thru this minefield.
The TV is also Pansonic so it makes *feck* sense to get their set top box. I also had heard mentioned that some boxes freeze and this may be down to a data buffer or caching - anyway, I guess this is sorted unless someone throws a spanner into this overnight.
RAM-man :cool:
Does any one know what the Ferguson FDTT2500 is like, as I'm after one with the card slot for the Top Up Tv, at the moment I cannot find any review's on it.
RamMan said "Is there a Which guide on choosing the right box ?.
Yes, just had a look and its 3 pages long.
Here you are.
Look out for these features when choosing your box.
Getting connected
Scart sockets
Most boxes have a Scart socket for connection to your TV with a Scart lead. Some have two sockets, which makes it easier to connect the box to other equipment such as a VCR.
UHF modulator
If your TV doesn't have a Scart input (Scart isn’t usually available on older models), you’ll need a set-top box with a UHF modulator, which connects to the TV’s aerial socket.
The picture quality won't be as good as with Scart, and you’ll receive sound in mono rather than stereo.
If your TV doesn’t have Scart connections, you’ll need a set-top box with a UHF modulator
UHF loopthrough
None of the Freeview set-top boxes lets you watch one digital programme while recording another on your VCR. However, if you opt for a box with a UHF loopthrough, you can record a digital programme while watching an ordinary analogue channel (or vice versa), with minimal disruption to your TV and VCR connections.
Audio output
Some boxes have a separate audio output, to connect the box to your hi-fi speakers. This is particularly useful if you plan to record digital radio broadcasts onto a Minidisc or other digital recorder.
Programming features
Electronic Programme Guide (EPG)
Freeview’s seven-day EPG lets you see what’s on all channels for the week ahead – but not all boxes let you access it, and some implement it better than others.
Our two Best Buy boxes – the Humax and Sony – display the EPG well – letting you scroll through listings, skip to the next day, see what’s on at a given time, and search by category (eg films).
The Sony shows seven channels at a time, along with a description for the highlighted show. The Humax has a simpler layout with larger text, but you need to press another button for information about the programme.
The manufacturers of the boxes that don’t let you access the EPG claim that you’ll be able to upgrade their boxes (via an over-the-air download), but many are vague about when this will happen.
Favourites
The ‘favourites’ feature lets you choose your favourite channels, making them quicker to access – handy with the plethora of digital channels on offer.
Timer
This lets you program the box to switch between channels at a certain time – handy if you want to record from more than one channel while you’re out. You’ll still need to program your VCR, too.
DVDs and VCRs with a Scart link feature make recording from different channels easy
Scart link recording
If your VCR or DVD recorder has a ‘Scart link’ feature (this is called various names by manufacturers, but it should be obvious from the instruction manual), some set-top boxes can automatically trigger it to record via the Scart lead.
This means you need only to program the set-top box and it will switch to the right channel at the right time and ‘wake up’ the VCR or DVD recorder to record, so there’s no need for a timer.
Convenience features
Controls on box
Some models have controls on the box, as well as on the remote control. This is useful if you lose the remote or its batteries go flat.
Remote controls work with other TVs
The remote controls for some set-top boxes can also control some basic functions of various brands of TV.
This means you can use just one remote to turn the TV on and off, adjust volume, and switch between digital and analogue TV channels.
Parental locks
These let you block access to digital TV channels using a PIN. Some boxes simply block all channels, while others are more sophisticated and let you to restrict access to channels of your choice.
top
Internet access
One Freeview set-top box, the Netgem i-player, lets you access the internet via your TV when you connect it to a phone line.
It’s not as flexible as using a computer, but it works reasonably well – especially in conjunction with the optional £30 cordless keyboard.
All the boxes we’ve tested deliver good pictures and sound, but some have much better features and are more user-friendly than others.
Freeview offers a seven-day electronic programme guide (EPG) across the UK. We would recommend only buying a box that lets you access this service, such as the Humax and Sony below.
The EPG lets you see programme listings for the week ahead and also makes recording easier, especially if your video recorder has ‘Scart link’ recording (see features for more on this).
The Humax F2 Fox T is a good box and currently £80 from John Lewis. It has lots of features and is easy to use. This is the best choice if your TV doesn’t have a Scart socket to plug a set-top box into as you can connect it via the aerial socket instead.
Some readers had previously reported that the EPG doesn’t contain the full seven-day listings. An ‘over the air’ software update from Humax has now been released which has sorted this problem although the ‘I’ programme information button is currently not working. Humax tells us that a further software update is planned that will solve this.
The Sony VTXD800 is a stylish box, which can be used horizontally or in an upright position depending on your preference (a bit like a Playstation 2). It’s got plenty of features, a decent EPG and, like the Humax, has a remote that can also control other makes of TV. It costs £100 from Currys, Dixons, Argos and Comet.
It is up to date(Nov 05) and offers some best buy guidance.
HTH
G C
that reminds me. i should point out that the pan box does not have a slot, so top up tv is not an option.
thank god ;)
Thanks Tuned, you don't happen to have the home page address for Thompson and Ferguson do you?
RAM-man said:
Cookie & Tuned-in
Thanks for dragging thru this minefield. The TV is also Pansonic so it makes *feck* sense to get their set top box.
RAM-man
Thanks Cookie & Tuned-in .
FINALLY !!! :spitfire ... I got around to doing it and like, Cookie got the Panasonic TU-CT41 to go with existing Panasonic TV - cos of the button features for use on Panasonic TV's only. (Richer Sounds £49.95 - bargin from the shop only).
Got it set up. Overall, picture quality and sound is very good but signal quality does vary, shopping channels (not bothered) but Five can be troublesome (caching > 50 to 80%) so I guess its at the upper limits of the Aerial, so do I now need a signal booster (any suggestions - what best to use) as I do not want to do a Rod Hull and mess around with Aerial's in a January storm. :confused:
Also.. I did a re-scan and found Channels 97 and 98 allocated - its not mentioned by anyone/anywhere, if anyone does have acess or the valid pin code then it will be truly freeview!. :D
Next is Currys :eek: for the Panasonic DVD player, £20 off, now under £40 :cool:
RAM-man
god this thread makes me feel old.
I well remember laughing at the Not the 9 o'clock news sketch. Some ordinary bloke wanting to buy a gramophone... 'Do you want salad dressing with your woofers and tweeters.' 'Paper bag on the head?'
I think I now understand how the poor bloke felt. think I'll go back and watch my old Betamaxes...
