Dinitrol 4010
MAR.600
GLASGOW
Hi
Looking at using dinitrol 4010 spray on my my 1250 engine . Is it worth using ?
Says its clear coating , does change colour or go off due to high temperature of the engine .
Has anyone used it before
Sent from my SM-G990B using Tapatalk
Yeah I used it on a few areas ,swing arm and engine, resists the heat well and stays on after washing, quite waxy bit does the job,even brushed some around where spokes meet rim as salt was causing slight furring.
I used some on my R1200RT LC silver engine and it goes yellow and is hard to get off. Probably OK on black though it gives a dull finish. I have used waxoyl and dinitrol soft wax on the underside of my 2002 r1150gs (I've had it for nineteen years) and the underside of the tank is good as new when you clean it off with parafin.
