Dipped Beam Wire
B4ndit
Hampshire
Can anyone tell me a good place to tap into the Dip Beam wire to switch a relay for Auxilery lights.
I've got the tank off and have exposed absolutely bundles of wire. Is there an easy wire to find here or should I look elsewhere?
Use the sidelamp wire a grey with a black trace as the switch for the Aux lamps relay
It means you can run the aux lamps on sidelamp only
I tapped mine inside the headlamp shell - easy to work out what's what in there :thumb
Looks like thats what one of the previous owners had done. The wiring fell to bits when I inspected it so whilst rebuilding it I just run another feed from that yellow/white wire.
Just waiting for my LED H3 bulbs now which appear to have got lost in the post.
