dipped beam
scubamouse
Bedford,England
Have changed the bulb in my dip beam but still not working main beam works ok
Have looked at earth wire inside headlight looks ok and clean.
Any ideas?
Mick
Deffo check the bulb - I've just had a duff new bulb when I went to replace my sidelight.
Otherwise check the fuse ???
Any ideas?
Mick
there are two wires going to dip if you have a tester switch ignition on and make sure power is getting through by checking both wires,think green is the live,if no power likely to be fuse if power must be a faulty bulb
