DIY Bash Plate???
john_aero
Glin, Ireland
Saw somethign here while ago for skid plate
looking make better job for the 1150gs, most only supply them for adventure.
want be able fit my crash bars and have better strenght.
anyone here made one or have a drawing for one?
are the rubber mounts necessary? can you just mount direct to eng or is it to do with vibes and act like mini shock absorber when bounce off rocks to stop casing getting destroyed
The 1150gs and the adv are the same bike with minor differences.
Mostly in seat, tank size, braided lines and colour.
A bash plate for a 1150gsa will fit a 1150gs as its the same engine.
had asked this earlier and told it wouldnt by members due to mounting
they do have different mounts and are different :thumb
left piccy = GS
right piccy = GSA
GS parts-
01 11111342936 EXTERIOR ENGINE PROTECTION PART 1 $96.16
02 11111341637 INTERIOR ENGINE PROTECTION PART 1 $27.60
03 11111340864 RUBBER MOUNTING - L=40MM........ 2 $3.93
04 11111340863 SPACER..................................... 1 $7.93
05 07119903791 WASHER - A6,4..........................................2 $0.50
06 07129904876 HEX NUT - M6-8-ZNS3 ............................. 2 $0.50
07 11111343054 RUBBER MOUNTING - L=47MM...................... 2 $9.50
09 11121738607 CAP NUT - M6.................................... 2 $3.23
GSA parts-
01 11117665608 UNDERRIDE PROTECTION...................... 1 $96.16
02 11117666706 BRACKET........................................... 1 $39.11
03 11117666292 BUMP STOP - 25X15............................ 2 $7.56
04 11117671170 SECURING NUT - M6............................. 2 $1.86
05 18127661043 SCREW - M6X8................................... 2 $3.19
06 07129903607 SCREW - M8X80................................. 1 $2.04
07 11117667353 SCREW - M8X14....................................... 2 $2.69
left piccy = GS
right piccy = GSA
GS parts-
GSA parts-
You'll also need the two ADV rear sump mounts which requires the main stand to be removed to fit them. And then you'll need to feck about with the side stand springs as the spring attachment is in a different location between the GS and the ADV.
must look into trying make one
how do the crash bars mount to the adventure underneath
mine are just bolted onto the smaller plate
