Driving lamps not working
Rugged Path
The Honourable.
Wybunbury, Cheshire East, England, EU
Before I start getting the toolkit out, I will ask a simple question.
A 2019 Limited model.
Albeit the console knob lights up when pressed on, I discover the driving lamps don't.
Do these have an independent fuse?
Bloody raining again.
Sent from my MI 9 using Tapatalk
I just removed one lamp and put a test lamp on the live.
Ignition on then, pressed lamp button. No power and all manner of CAN Bus flashing lights began.
No doubt all linked via the ECU.
Driving lamp off and all is calm again with ignition on.
Fixed and all back to lovely normality; now that the days are getting shorter.
I had previously removed the cast alu stalks that holds the lamp & indicator when installing lower fairing insert lights and harness. On the right side one, a gray/white wire was snagged whilst tightening the two fork leg dome nuts down.
So, extra protective sheathing around wires and tucked in better.
