DSA Questions
Martin GSA UK
East Coast UK
I've introduced myself in the New Members section. I have a new 1300GSA with adaptive ride height (not 'comfort') and 'Pro' ride modes. I have a couple of unconnected queries, which I'll cover in separate topics:
I have previously owned a 1250GS and 1250RT, both with the 1250 versions of DSA suspension adjustment. On those bikes there was a very clear difference between 'Road' and 'Dynamic' modes. On my 1300GSA I've convinced myself switching between the two suspension modes isn't making any difference at all. I even went into settings and put Road mode at -2 and Dynamic at +2. Still no noticeable difference.
So convinced, I went back to my supplying local dealer this morning. They checked it and confirmed it is working as designed. Their test, which they re-did with me, with the bike still in my -2/+2 settings, was:
- with the bike standing off side stand and with engine running, with Dynamic selected, bounce the bike up and down.
- then switch to Road mode. Listen for the servo and watch a very slight drop in ride height, then bounce the bike again.
I heard the servo and saw the ride drop very slightly, but the difference in bounce between Dynamic and Road wasn't that noticeable. If I was looking to be convinced, perhaps Road mode was a little softer and bouncier. But not really noticeable.
I asked why they seemed to ride identically. They told me:
i) that the latest 'Evo' system is more sophisticated and is reading my riding and Road feedback more than the earlier system, to improve the bike dynamically, resulting in a closer performance;
ii) when BMW spoke to customers they wanted more control and less bounce in ride mode, so for Evo DSA the two suspension modes are closer than pre-evo;
iii) at my first service, booked for the end of the month, they will 'recalibrate' some aspect of the suspension (I don't recall exactly what they said they would recalibrate), which will take approx half an hour extra.
My software is the latest version and the battery is AGM and fully charged.
On 1300GSAs, are you finding the two suspension settings are very similar?
If not, has anyone had a similar experience and solved it?
Many Thanks,
Martin
dynamic on the older 1250's would wind up and down the damping as you rode - aka it responded dynamically (hence the name) the quicker you went the firmer it got
ride like you have a death wish and it gets too stiff for British roads - where it makes it more likely to lose traction - as the damping is way too stiff and you bounce off the bumps rather than absorb them and thus it helps you throw it down the road - its a well known issue on the S1000RR
its a marketing idea trying to make budget shocks seem clever - if they had set its max compression damping a few clicks back it would be OK - if you compare when stationary why would dynamic be stiffer - it ought to be softer - as it can stiffen as it goes when necessary
part of your confusion might be that its not changing the spring rate just the damping - now based on design and so forth everything muddles into each other - but the gist is a steel spring of X rate will always behave the same - if you preload it the rate is still the same (but you'll regain ride height and it makes you think its different)... and when you have more compression damping it will make you think its stiffer - slower to react would be a better description - till you restrict the flow so much you have locked it up (and we bounce off the bump as I mentioned earlier)
Riding style does matter and so does weight. Kitted I weigh close to 100kg and ride relatively quickly. There is a huge difference between the modes and you should feel it.
The road mode +1 for me is comfy round town and in the rain. I have the dynamic set at +1 as well on faster corners the difference is night and day. In live in France and the roads are much better which does factor in.
Have a read of these threads…
and…
Might explain things for you?
The difference is very subtle; it’s not night-and-day different 👍
Yep, I'm familiar with damping vs. spring rate. But in fact, as I understand it, the Evo suspension does change the spring rate, by c.20% between Road and Dynamic, by using the hydraulics and additional spring(s?) In the little tube adjacent to the shock. I guess my issue is, regardless whether due to springs or damping, on my two previous 1250s, the real world riding difference between Road and Dynamic was clear as day and it isn't on my 1300GSA. I find that suspicious.
and…
Thanks. I'd read the +2/-2 topic when researching my apparent problem, but I hadn't seen the video, which was very well presented. I noticed he seems to say the differences he makes in the settings are obvious. I'm not finding that at all.
I'm an experienced rider, over multi-decades and enjoy a spirited ride on twisty roads (Picos, Pyrenees, Alps in the last couple of years, regularly N. Wales and N.W. Scotland). I found my 1250s really good on these roads and definitely benefited from being in the Dynamic setting. I would only use Road on rough surfaces and motorways.
I'm a pretty average size: c.180lbs /82Kg, so I think I should be able to detect a difference in the suspension settings. The posts and YouTube videos I've seen seem to support the changes between modes still being readily apparent on the 1300s, despite moving to the Evo system. I'm not finding that to be the case. That's why I'm concerned I may have a fault with my GSA?
The main difference between Road and Dynamic is not necessarily going to be too noticeable. Road simply doesn't adjust anything on the fly, it's a static setting, although you can set the dampening +2 -2. It's a good all round setting that behaves well in 'most' situations. Dynamic will be constantly adapting to conditions so the only difference you will feel is that it behaves in 'all' situations. But Dynamic is more than just suspension, it's brakes, ABS, and most notable, throttle response.
Yes, I adjusted Dynamic Pro, so that it would have the same abs, traction control and throttle response as Road, just so I could compare the only other variable, the suspension. I did this just to check it wasn't a problem with switching between suspension settings on the hamburger button. I think I've tried all permutations to compare just the suspension variable.
Interested in what you say here:
"The main difference between Road and Dynamic is not necessarily going to be too noticeable. Road simply doesn't adjust anything on the fly, it's a static setting, although you can set the dampening +2 -2. It's a good all round setting that behaves well in 'most' situations. Dynamic will be constantly adapting to conditions so the only difference you will feel is that it behaves in 'all' situations."
I don't really understand that. If you can expand on the explanation I'd be grateful, especially if it points me towards something I can test for. My expectation was that Dynamic would still contrast to Road, being a firmer damping. Especially as I have Road @-2 and Dynamic @+2. My research so far, suggests what's generally reported (here and YouTube) as a clear difference being evident to the rider. I'm not feeling that. Yet I think I'm experienced enough to be able to notice a difference.
Not sure how I can expand on that. I will say that trying to test for specific differences between Road and Dynamic will be difficult, however if you're riding hard particularly on rougher roads you may notice traction control light coming on a lot or unsettling suspension in fast bumpy corners with hard power coming on. Dynamic can smooth out some of this behaviour. The one huge difference between the two that you can feel right away is throttle response. In Road the throttle is softened, the power comes on but it's applied a bit slower. In Dynamic it's instant hard power right away. The thing about dynamic suspensions like the BMW or Ducati or whoever else, you won't feel anything, it just works and you give up thinking about it.
Also as you've probably seen, Dynamic Pro doesn't give you anything more, it just lets you reduce things
did you read post #2 the main outtakes
Hi, yes I did read it and I didn't understand it tbh, it doesn't match my experience of the 1250 system. I've ridden hard on UK roads in 'Dynamic' mode and it was never a problem. Happy to be shown I'm wrong, but I didn't believe 'Road' mode switched off the dynamic adjustment, rather it just reduced the damping. I think the confusion stems from BMW's name for the two modes. 'Sport' instead of 'Dynamic' may have been clearer?
I had assumed the new Evo system did the same as the old, except with added spring adjustment and enhanced detection/data gathering. My understanding is both Road and Dynamic suspension modes are 'intelligent', just the former is softer than the latter and I should be able to notice it. Reviews I've read and watched tell me it's clearly noticeable, but not on my bike.
On my 1250s the difference in the modes was very obvious and welcome. On my 1300GSA it isn't. I detect no difference across a range of road types, when riding gently or when pushing it harder. I've tried to convince myself there is a difference (I'd prefer not to have a problem!) and failed.
Is the difference between modes clearly noticeable on your bikes? That's probably the most helpful feedback you could give me.
If it isn't particularly noticeable, all good, mine perhaps is fine.
If it is noticeable, then I think I have a problem. 👍
Hi, yes I did read it and I didn't understand it tbh,👍
you are correct that they have bastardised the use of the term Dynamic for a good few years.
With DSA they have started using the word Dynamic, correctly. AKA changes on the fly "Characterised by continuous change, activity, or progress".
Whereas the marketing team for the last 13 years, has been misusing it to infer an exciting, sporty or lively characteristic
page 184 of the R1300GS user manual
DYNAMIC SUSPENSION ADJUSTMENT (DSA)
with Dynamic Suspension Adjustment OE
How does DSA work?
Dynamic Suspension Adjustment (DSA) is as semi-active suspension-adaptation system that reacts automatically to riding manoeuvres and to surface conditions. By interpreting ride height sensor signals, DSA detects movements in the chassis and suspension and responds by adjusting the damper valves.
Additionally, the suspension characteristic can be set up to suit the desired riding experience. This is accomplished by automatic adaptation of the spring rate in addition to the damping, depending on riding mode.
Load equalisationDSA adapts the motorcycle automatically to the load it is carrying. The rider does not have to adjust the suspension to suit the load.
When driving off and when riding, the system monitors the suspension at the rear wheel and corrects the spring setting in order to set the correct riding position. The damping is also adjusted automatically to the load.
This is muddled claiming its a first on the 1300R - but the GS user manual says the GS already had it https://iamabiker.com/avin/2025/bmw...-dynamic-suspension-adjustment-dsa-explained/
Dynamic Suspension Adjustment (DSA), makes its debut on the 2025 R1300R roadster, and it’s a pretty big deal.
Until now, electronic suspension systems mainly adjusted damping – basically how fast the fork compresses and rebounds. But BMW’s DSA takes things further by simulating a stiffer or softer spring feel, depending on the riding mode selected.
Here’s how it works:
At the base of the fork leg is an external reservoir. Normally, oil displaced by the damping cartridge flows into this reservoir when the fork compresses. But with DSA, an electronically controlled valve can block that path.
When that happens, the oil is redirected to act on a piston positioned underneath the spring. This hydraulic pressure pushes the piston upwards, adding compression from below. The result? The spring gets squeezed from both ends, increasing overall resistance.
Better than preload?
Yes, and here’s why.
Preload simply compresses the spring before the suspension starts moving. It raises the ride height and reduces sag, but it doesn’t change the spring’s stiffness. The spring still resists compression at the same rate.
Spring rate, on the other hand, defines how much force is needed to compress the spring over distance – and that’s what DSA adjusts dynamically. It alters how the fork reacts through the entire travel, not just at the start.
How does DSA work?
Yes, I started with the BMW handbook. Unfortunately it doesn't answer my question about whether owners can tell a clear, noticeable difference between Road and Dynamic.
when I activate Dynamic modes its usually means a slightly less refined but overall more controlled set up when riding with your brain missing
all the rider modes in small ways have some meager benefits - if they just gave one decent set up we could ride in more comfort and safety more often.... its all about marketing benefits (regardless if of any use) to extort cash
Make sure you're switching between the road/dynamic suspension modes using the hamburger menu, as that's the only way to guarantee you're actually changing mode. If you use the RH mode button, there's no guarantee you'll get the suspension mode you think, because each riding mode remembers the last suspension setting it was in, and always reselects it. So with the RH mode button set to "Road" it might select Dynamic suspension,if that was what you used last time.
If that's not it, all I can say is that on my GSA there is a clear difference between the two modes, although it's not night and day. I need to have Road on -2 to make it good for comfortable touring.
Thanks for the info that you feel a clear difference. Yes, I use the hamburger button.
Just took out my dealer's demo 1300 GSA, just like mine except the adaptive ride is the comfort version. Pretty much exactly the same result as mine. The difference between Dynamic and Road on the 1300s seems minimal, not like the 1250s. A black mark in the 1300 vs. 1250 contest! At least I know mine is OK. 👍
How is it a "black mark"? Is Road mode worse that the 1250 or is Dynamic mode worse than the 1250? Or is it that you don't feel a large difference that's bad?
It is 18 months since I last rode my 1250GS, because I had an RT in between. My memory from 4 years of the 1250GS, 38,000 miles, was a fantastic Dynamic mode, the bike was tight and easy to steer. But it transformed to a serene float in Road. For me, Road was only used on dual carriageways and really bad Road surfaces. Dynamic most of the time.
The 1300GSA seems to have Dynamic (rather than 'Road') and Dynamic plus a slightly bit more. Bear in mind, Im one week and 320 miles in only. I think the Dynamic is fine. I felt I was 'back home' when I tested the GSA prior to purchase. So it will do just fine. But, I think I will miss the motorway sofa mode on long motorway stretches.
