....on an XChallenge?
Looking to wire in some auxillary lights.
I've got a relay and fuses to run the main feed from the battery to the lights, i just need a switched live to feed into the coil side of the relay.
where is the easiest place to tap into the loom? or is it easier to pick up from the back of the dipped side of the headlight? or somewhere else?
I the auxillary socket under the seat switched?
