This is baffling me.
When switching on the main beam it doesn’t come on, worse still the dipped beam goes off! I’ve checked inside the headlight and the bulbs ok and the light relay seems to be working fine. The blue main beam indicator comes on when the main beam switch is used and that seems to be on the same wire (white) as feeds the headlight.
So effectively there’s two problems: 1) loss of feed to the main beam connector on the headlight, 2) loss of feed to the dipped beam connector when main beam selected.
I’m stumped!
R
I’m stumped!
R
