I would appreciate any advice that you guys can give me to help sort out my heavy handedness. I have a 05 GS1200 with 60k miles.
I had a problem on a ride out on Sunday where I got a misfire under load that manifests itself when I either get to around 4k revs or crack it open at any revs. The bike (according to my mates behind) smells of unburnt fuel.
I concluded an ignition problem and duly ordered new plugs as a starting point. My friend who has an identical (although much much cleaner) is good enough to let me try his coils so we can eliminate that. He lies the problem.
As I pulled of the HT/Coils from the plugs the RH secondary connector into the coil disintegrated (the pictures show the damage). Obviously the connector need replacing, Half the connector is still in the coil (pic1) Do the prongs come on the harness or the connector? Can I buy the connectors anywhere? Is it a BMW only part? Can a decent auto electrician fix it, or do I need to get it to a dealer?
Any help would be appreciated.
Cheers Steve
Cheers Steve
