Oz1200
(2005 R1200GS)
I couldn’t get the angled coil/plug cap off the left hand side spark plug, so stupidly gave it a quite a tug. It came off with a rush and I managed to break the coil where the electrical connector goes in and crack the connector on the wiring harness itself. I can now see why the Haynes manual says disconnect the coils before removing them.
I can replace the coil – all it takes is money – and will attempt to repair the old one to keep as a spare.
The small 3 pin connector from the wiring harness that goes into the coil is a different issue. The plug is cracked right across and I’m worried it will fatigue over time. Whilst still serviceable (I think), I want to fix it. The local dealer was not able provide a replacement plug.
Can anyone help with a part number, or the name of the manufacturer of the electrical plug that goes into the ignition coils?
Does anyone know how to remove or install such connectors? They do look like they are supposed to come apart.
Any help would be very much appreciated...
