Electrical switching
  • Thread starter Thread starter ColBol
ColBol
Can anyone recommend a simple robust waterproof switch for lighting, but not the rocker version as seen on previous threads?
switches.
I have used a toggle switch from Maplins, these are penael mounting I.E. they mount through a plate or such with a lock nut. water proof toggle cvers are available which fit over the toggle. These are brilliant have had tweo on my GS for about three years on a fog and spot lights (before hid's) no problems. |they are quite solid designd for 240v 15a so no problems on bike.
dave (not a Maplins shareholder!) gs.:beer: :beer:
PIAA waterproof switch from Nippy's part no. PIA - 74034. At £19.00 it's very good value for money. It comes with 1 metre lead, 3 pin connector, sticky mounting pad and has 2 colour LED for on/off.
Nippy Normans Autoswitch. Excellent solution. I have two fitted, one activates with "two quick presses" and the other with a "press and hold" on the indicator cancel button which on my bike is where the right ticker should be :D
