My 1978 80/7 has had a Boyer Bransden electronic ignition system on it for the past 31 years and 130,000 miles. I have borrowed Pastymans xenon timing light (thanks Tony) to check the timing as Rob Farmer
said at the Wee..kend it sounded on tickover like it was a bit out. Anyway whatever I do I can't get it right at tickover and 4500rpm. If I set it correctly for tickover on the S mark in the crank case hole, then at 4500rpm the F mark has not appeared and I can still see the bottom of the S marks if I look from below towards the top of the hole. So at the moment it is set advanced on tickover (800rpm) with the S mark just starting to appear from the top of the crank case hole if the tickover fluctuates below 800rpm, which it tend to do as this makes the tickover a bit lumpy.
So the question is has something happened in the magic box of electronic tricks (transistor box)
that must alter the timing depending on the rpm as the auto advance unit is removed with this system?
Should I get a complete replacement timing system?
http://www.motorworks.co.uk/bmw/pro..._15_20_IA_40&header_text=&header_text_image=0 I really don't want to go back to points again.
said at the Wee..kend it sounded on tickover like it was a bit out. Anyway whatever I do I can't get it right at tickover and 4500rpm. If I set it correctly for tickover on the S mark in the crank case hole, then at 4500rpm the F mark has not appeared and I can still see the bottom of the S marks if I look from below towards the top of the hole. So at the moment it is set advanced on tickover (800rpm) with the S mark just starting to appear from the top of the crank case hole if the tickover fluctuates below 800rpm, which it tend to do as this makes the tickover a bit lumpy.So the question is has something happened in the magic box of electronic tricks (transistor box)
that must alter the timing depending on the rpm as the auto advance unit is removed with this system?Should I get a complete replacement timing system?
