engine problem help please?
Bengaz
South Shields
Hi, after removing and refitting my fuel tank yesterday i cannot get my bike to run properly. It is only firing on the left hand side. And even then took ages to start.
Any ideas, something daft like fuel lock or something, I really don't know:(
Sounds like you have caught throttle cable going into splitter, left hand side. Just remove bolts and lift tank slightly, you should be able to correct without having to disconnect everything .
Prop
Thanks for that, I did catch the throttle cable on the left and it pulled put of the box a little but it just sprung back in again. Out of interest how could that stop the right hand pot firing ?
Found the right hand side cable pulled slightly out of splitter box. Thanks for help!
