Hi folks
Settle down this is a long story !
Firstly some background history. I bought this 2009 r1200 GS just before the COVID lockdown paid too much £4200 ( I think) 60 odd thousand miles half decent condition. Full luggage with a few scrapes and some service history . Bike was put away and hardly used. As a key worker ( allegedly) work took over .
First couple of short outings on the bike when things eases up and the Starter motor failed , replaced and now starts ok. Another 12 months or so and only a handful of miles the Clutch Slave Cylinder failed , this was replaced along with pushrod and felt. Clutch bled and all working again. .
Dragged out to go for the MOT this year and the rear brake master cylinder had failed ( it never ends);So again this was replaced and MOT,d all okay .
Now I have only ever had jap 4s and I find the engine noise agricultural to say the least . It's quiet when it starts up and goes up through the box fine and pulls ok . But !! It makes the most horrendous racket when accelerating from 3 or 4 thousand revs until the wind noise drowns it out.
Even my wife comments that it's like a bag of spanners! Valve clearances and end float checked. Plugs changed . Engine oil and filter changed.
Still the rattle exists . When I'm riding it seems like it's coming from down by my left boot at the back of the engine. Though I'm aware the noise might travel.
So , the next saga. Both final drive rubber boots had small splits. I had these ready to change so today I took the plunge and stripped the bike down.
It all came apart ok , splines both ends were good. No spring clip on the gearbox shaft though ? No rust or water ingress.
I've checked the driveshaft as best I can and there's a very slight notchy feeling the final drive end and gearbox end feels ok
Now I was hoping that I might find the driveshaft was knackered and was causing the racket. Looking at I don't think it is ?
The problem I have found though is there seems to be an oil leak on the internal side of the final drive.
Now I have no problem getting the driveshaft checked and the final drive oil leak fixed. It's just if I chuck a load more money at and get it all back together and it still rattled like it's going to implode. I'm back to where I started . It's pretty frustrating as I don't want to spend the money and still be unhappy with how it sounds.
Just looking for some advice really. I could stick it all back together and sell it with the faults described honestly. Or get it fixed and enjoy it.
Hopefully you are still reading and haven't nodded off . Thank you
