RoyF
Cheers for that again Santa,
Bike is an - R1200 GSA (90th Edition)
Year - 2013
Build Date - 11/02/2013
That's exactly the same page as in my manual, (although I believe mine is an 0470 model for the UK rather than 0480 which could be for the EU maybe but I could be wrong?)
Tried it both ways, sitting on it at a set of lights etc which I sometime did, and also tried it on the centre stand which made no difference.
It always has worked as per the manual, it only came to light that it wasn't working when I was out with a mate who has the same 90th Edition bike, built a few weeks before mine, and his was working as soon as the engine just got up to temp without fail, and mine didn't.
Yep, your second pic is the oil level sensor, with the connector just below the cable ties. Tried a known good sensor (which works fine on my mates' bike) and still had the same fault.
Which took me to checking the cabling back up to the ECU. So I metered the cable out with the ECU disconnected, down Pin 45 to the float and back up Pin 40 which checks out fine on the multieter, which then took me down the rabbit hole of was there a parameter that the ECU wasn't seeing correctly (Engine Temp, Side Stand Switch etc)?
As per your suggestion, I'm going to have the tank off again today if time allows, as it's still just about empty and the panels are still off, and put 12v down pin 45 of the dosconnected plug, through the float and back up to pin 40, then through a 2w bulb and back to groiund and see if it lights up, could be its reading ok on a meter but corrosion or a break between the two along the line is stopping any sort of current flow? At least that should at least confirm both sensor and sensor wiring.
Hi Botus,
Yes, been through the coding on GS911, both Engine and Cluster, both look to be set up correctly with level sensor enabled in both places, even tried disabling re-testing and re-enabling again but made no difference.
Roy.
Year - 2013
Hi Botus,
Roy.
