ESA 2??
Just one thing I do not understand with ESA 1 or ESA 2 is:-
If you have two fat gita at 20stone getting on a bike and two thin gits of 12 stone it is the same button that you press to get solo, two up ot whatever.
The spring adjustment should be different in each of the above cases. As there is no manual adjustment when you have ESA how can it work for both scenarios.
